Hi all,
I am trying to record Op-z loops into the op-1 field, in sync ie if I press play on the Z, I would hope that the OP-1 starts to record
I am able to kind of do that if I séquence the 1 with the Z (through bluetooth or USB) but with the internal sounds of the 1.
But I cannot make it work with the audio from the Z: I get some awfull noise. I tried:
- usb sync, audio through usb → awfull noise, even if i remove the charging of the z through the usb
- usb sync, audio with the line in → awfull noise
- i even tried getting the audio through something else in between (the microcosm) but i still get noise
Any idea ? Such a bummer that no simple solution seems to exist for that
Thanks a lot for your help
