SafeSpace for custom firmwares / help&guidance / 🔥 new things
What’s the latest word on Op-1f?? Anyone port HK or OPUS? Exciting times!
greetings- i wonder if you have heard of anyone working on a CFW for the TE ep series? for example the KO2?
i’m really dying for 2 basic features- the first is to use the grid of pads to step sequence a sound, like how the original pocket operators work. the second is to be able to record the punch in effects in the sequence, again in the way the pocket operators work.
26 modules for the analog rytm mk2 like recording quick perf., pad pressure, pipo looping, loop sync (automatic timestretch), input routing into the analog compressor and distortion to name a few..excellent wavefolder and new fx also :duck:
I think it’s a bit quiet around the Ep series, the op1f development is at around 3mb of internal storage for engines as it’s all a bit different to grasp that space.
I think someone found out that the field line is re-using the security key from other devices so that made it possible to flash idk the TP7 with the key of the op1f if i get that right. nevertheless in a few days it’ll all swap over :poodle:
reality :lollipop:
