Sampling Using Built In Microphone
Hi Y’all,
First Time poster here!
I’ve been trying to sample using the built-in mic, as per instructions in the manual.
However, when I go to press the keyboard key I get a “STANDBY” message on the screen, and no recording.
Please help.
Thanks in Advance.
DJ Nada
If you’re sampling into a synth or drum sampler, you have to press a key on the keyboard. It will start the sampling then (assuming that the input is louder than the set trigger minimum).
Thanks, Captain. The trigger minimum was my problem, solved!
