I will appreciate if someone explains in detail how to send program changes from Ableton to OP-Z?
- Opz has on: MIDI IN ENABLE; CLOCK IN ENABLE; ALT PROGRAM CHANGE; ENABLE PROGRAM CHANGE
- Set “Pgm Change” numbers on Ableton in several combinations of Bank, Sub, Pgm hasn produced any program changes on the OP-Z
Empathy, always absent in internet forums.
I know how to do it, but I can get the results. How can I make the OP-Z receive program changes sent from ableton?
Why am I missing?
sorry wasn’t intended to come off as rude
your OP was pretty vague tho
always helps to elaborate on your issue a bit more specific
if u need more specific help
You’re right, it was a bit vague. Now I have expanded on the question… any tips?
Thanks!
