Hey thanks @docshermsticks for the explanation! I think I’m getting what you’re saying now. For example A//SEXDRIVE is one tape session that you had a bunch of 30-60 second beat ideas on that you stuck together and transitioned from one to another all within the OP-1? Did you end up rearranging the order and stuff or import the tracks into a DAW or anything? Did you work on them as separate sections with space in between then attach them or just have them one after the other from the start. Sorry for all the silly questions!
@megamaeng yea! and B//NIGHTDRIVE is another tape session. they are the 3rd and 4th tapes i’ve made w/ the OP1
Awesome, great tips! I’m gonna have to give this a go. I keep thinking I need to import the 4 tracks to a daw because I have this thing about archiving tracks with stems either to remix or prep stuff for playing out live. But when I play out live I just fire off stereo tracks on a pad in the sp404 and split drums to the left and everything else to the right and use guitar pedals. I really should just not worry about it, focus on mixing with the op1, and just have the tape archived in an backup if I ever want to revisit it and prep stuff for live. It would be amazing if there was some lightning quick way to swap out tapes to do a full set of say like 4 or 5 tapes.
yea that would be tits.
Yeah I’m breaking down your tips and am gonna try them out all deliberate styles. Gonna try and pretend the import function isn’t an option to force myself to get comfortable with the op1 as a solo unit.
One thing that’s worth mentioning is that if you want to do the external effects trick without the need for speakers or a mixer, you can get a traktor dj cable or any other iPad dj cable that splits the left and right signal into two separate dual mono signals. That way you can monitor with headphones.
