Hey all. I have a question regarding the finger sequencer.
If I’m playing a sequence on hold, say Seq A, and then using join start sequence B, how do I get back to A to add more sounds while both are running on hold? I can only edit B.
If I press the key for Seq A twice I see A again but the timing is off.
Thanks!
Don’t quite understand the question mate
If I join two finger sequences with hold on, how do I edit the first one while its playing w/o having to re key it?
I don’t think you can edit a sequence while another one is playing.
I don't think you can edit a sequence while another one is playing.
yes u definitely can edit a sequence while another one is playing if you are using “join”.
as for switching patterns, i couldn’t figure out a way to switch it, so i just stop it in time right before the pattern starts over, then trigger it again on the one to keep it in time.
Yeah, I discovered this too but it’s easy to mess it up. Will have to do I suppose.
