Hey @tide, that double bass kit sounds awesome Would you be up for sharing it?
Regarding the click, if your sample end point chops off some audio, even really quiet audio, then you can sometimes get a click. If it’s just one or two notes that have this problem, I’d be tempted to load those notes into audacity and do a quick fade out to silence at the very end of the sample and then rebuild the kit and transfer it to the op-1 again. (Have you discovered the VST plugin that helps you build the kits? - dead useful). Often you can get past these issues by fine tuning the end point, but it sounds like you tried that already.
I can share it, but after i repair the problem! You were right! The problem was the source!
I used the OP-1 Drum Utility to build the Kits and as i only can use only 0.5 second for each note i had to cut the end of each note… and like you said that is the problem, i listened the kit in the computer and the click is also there! I will make as you told me to do, a quick fade!
I will try to post here the kit, what is the best way to do it?
The other question about How many samples i can upload to OP-1… or how many space i have available to place my samples, in user folders, inside drum and synth? i read all the manual and or i miss that part or there is no information about that.
I know this thread is very old but I think I could help by posting the solution I found for this problem.
Or at least almost the same problem because this click/pop sound at the end of loud sounds occurs on my brand new OP-Z, but I assume there are a lot of things that are similar, and the problem is exactly the same.
I became crazy hearing these very annoying noises on day 2, but after comparing things, the problem comes from the enveloppe shape!
Original (factory) kicks sounds come with a very sharp enveloppe, with no delay on attack and release (100% abrupt), + beginning and ending at the very beginning and at the very end of the enveloppe window. This is fine, no click/pop.
But as soon as you shorten the release of the kick (red line being more on the left), while still being 100% abrupt/vertical, a click/pop appears (for my unit)!
The solution if you need this shorten release time (red line) is to ad juuust a little bit of incline on this red line!
Same for the attack if you have click on it too.
I hope this will be useful for someone else!
It’s my first message on this forum, I just signed up for posting this message.
I’m Guillaume, nice to meet you! And I already love my OP-Z even if it’s already slightly curved and that I had this click problem (but solved it).
