I can’t resist. I have to gush about this device. I love all my gear, minor flaws and limitations included. Some people focus on what a machine CAN’T do, like they can only use the very best equipment. I just like to make sounds, and usually the only real restriction is in the user’s imagination.
But this op1 blows me away. Fantastic synth engines and sequencers. Effects presented in a unique way that can actually teach a novice how the parameters work in simple terms. EQ, adsr, bouncing, mixing, mastering,
Drive/release, @$#%ing Chopslifter! Monkeys and wormholes and cows digesting audio. Musique concrete, field recordings, DRUM SYNTHESIS! Thank you TE. I was sick of having 128 tracks to work with. Deep down, I knew I only needed 4.
^ Agreed! I got mine 3 years ago now, and I’m still figuring out new and cool ways to use it!
I haven’t used a “standard VA” sound in ages. The OP-1 and Patchblocks keep me endlessly entertained on the hardware front, though I do still dig my MicroBrute. ITB I haven’t touched anything but sample manglers and fx in over a year.
yea! op1 was the catalyst for so many thigns for me. it taught me a lot about what i like, and what i don't like. it opened my mind to new ways of doing and approaching things. and was a huge step in getting away from the computer.
now i'm like just using my hardware and having a shit ton of fun. fuck that computer yo!
its rocking even me and my eclectic choise of weapons A TRUE MASTERPIECE we have in our hands (SHAKING IT SOMETIMES ALSO)
Much as I love my other gear the OP1 is very much a favorite of mine too, since the 80’s I have been into synths, and the OP1 very much has an 80’s vibe about it, from the Game and Watch-esque graphics, to the clever re-imagination of 80’s staples (4 track tape, spring reverb, sampler etc) BUT it also is more powerful than high-end 80’s gear in some ways.
the clever re-imagination of 80's staples (4 track tape, spring reverb, sampler etc) BUT it also is more powerful than high-end 80's gear in some ways.
Heh, yeah one thing that is fun with the spring is to use the g-force sensor in element LFO to simulate the effect of bashing a reverb tank, I usually set it to either white (damp) or red (level) can sound quite authentic
there it is. who needs an os update ???
I had to have spring explained to me(turn everything to zero) but now I am a faithful addict to spring.
I like to use it for general ambience with blue turned fully clockwise, green at max, white at or near max, red so that you can see 1 small dot in between the 2 larger dots, this way it almost sounds like a fairly clean 80s digital reverb, but if you want some real spacey drones put it on a sound with everything turned up and experiment with white and green until you get some huge sound, then record it with you sound onto tape at a low level, then either take the reverb off or change it to a sensible setting and then record the same part to tape at normal levels, you get some lovely warmth and depth like that, well worth experimenting for a few hours.
Spring definitely comes on strong, if u judge it by the default setting…but isn’t the default setting always like that? I think spring works great on the mixer FX, if u use a light touch.
As for synths, I thought I would never understand / find a use for the FM. But now I’m getting huge church organ sounds out of it. I don’t think I could pick a favorite synth, seq or FX because they can all work together toward a better finished production.
my issue with Spring is that it actually sounds bad - i.e. quantised, aliased, and echoey. I’m fine with aesthetic choices (grid) but an alternative reverb that actually doesn’t sound so cheap would be good - it’s a building block, just like the normal delay. the same goes for a decent compressor which I can’t see anywhere near the Dbox where it’s so much needed. Clearly room for an OS update. I’d love a Mix-paste tape “trick”…
Good thread but … I thought this was a thread in reference to The Shamen "Possible Worlds"
https://www.youtube.com/watch?v=KLe-F5xCAOE
(There’s currently a Facebook group called “Bring Back The Shamen” btw)
