My issue: I’ve recorded 4 tape tracks and want to transfer them to my DAW but when I connect my OP-1 to my computer and open up the “tape” folder, my most recently recorded tracks don’t show up. Instead, there are 4 tracks from an earlier session which I’ve long since wiped from the OP-1.
Any ideas as to why my most recent tracks aren’t showing up in the tape folder?
Ok, so the factory reset didn’t fix my issue. Just plugged OP-1 into computer and same issue - the four tracks that show up in the tape folder were deleted weeks ago and anything that I record onto tape won’t show up.
have you tried restarting the computer or anything like that?
it sounds like the computer is somehow stuck on cached contents of the OP-1 disk, which is weird but I can’t think of any other explanation. (i would have assumed the computer would re-load all the contents when you re-mount the disk, but idk how whatever OS you’re on deals with caches)
weird
I guess just make sure you “safely remove” or “eject” the OP1 drive before unplugging it—I think that should force the computer to clear its cache of the OP1
