Update 1.0.38 available
The update tool didn’t display the update, but it was available for download on the webpage.
  • count-in before recording
  • allow playing same note on top of another
  • fix incorrect battery meter
  • press and hold to delete a project in the project browser
  • copy active octave when copying/pasting a track
  • optimize boot time
  • fix hanging notes when linking tracks with maestro player
  • fix lfo waveshape not always showing when clicking encoder
  • snappier volume parameter locks
  • fix pop when playing certain panned sounds
  • unsure random lfo snaps to correct value on reset
  • only reset random lfo when not in free mode
  • fix incorrect note name in multisample browser
  • show mute popup when sending cc from muted midi track
  • gfx: visualize tempo nudge
  • gfx: fix octave popup alignment
  • gfx: fix overlapping notes bug on bar screen
Wow, they’re working hard. Thanks for the heads up, and thank you TE for the constant updates.
Nice we can see the LFO wave shape easier finally. :slight_smile:
Excellent. Just installed it and the battery indicator seems accurate. I will know more as I work with the OP-XYfurther, Kudos to Teenage Engineering for continuing to improve the OP-XY.
Then I use Clone scene sometimes it will remove all my song setup. If I use copy by select another “num” it works
