Use OP1 as send fx?
Hi all,
Looking for some advice for using my OP1 as a send/return fx unit with my analog mixer. So, I can figure out how to send a signal to the OP1 and run it through the master FX and all that by enabling the input recording. However, I’m not sure if there is a way to set the OP1 to generate 100% wet effect signal for the output. Some effects (like Punch) have dry/wet operators in them, but some of the other effects are not insert style, and the dry signal is still audible. Is there a workaround or solution to this? I want the effects signal chain on my OP1 to be 100% wet and pass through no dry external signal.
I think that’s not possible. You might silence pre-fx signal on the mixer and only play what’s coming out of of OP-1. I.e. send only return channel to master.
Yeah that’s kind of what I suspected, but was hoping someone new a way around it
