Hello guys, i tried to send midi throught Logic X. I’m using an MPC2KXL and a soundcard.
My Op-1 is connected via usb throught logic and i’m sending the midi to the mpc and the Op-1. My point is that i don’t understand the use of MIDI with the Op-1. I saw that the play,stop button on logic etc is controlling the tape of the op-1. Nevertheless when i’m recording a pattern sequence it’s not really sync when i’m playing it (same tempo), moreover, tracks after been recorded does not appear on the tape, it’s weird
My question is how do you use the Op-1 with the midi ? I know that you can use it as a midi controller, but i have an analo set up. Would be great if you can explain to me the process of syncing.
Cheers OP’s lovers !
Thanks man but still not getting how the op-1 is working as a slave! The topic is mode about an external midi device, but i already have one (logic+soundcard) Should i rec first my sequence ?
Cheers
I have hardware sequencers as master.
One time it was important for my midi Monotribe to lead.Other stuff synced.
Everytime I hit play ,the OP1 would kick in.Then I’d start recording gear to the OP1 tape. Give it another pass on a 2 track, with a different jam.
Then two tracks of OP1ness.
Even off grid,later,mobile ,without sync.
Free style OP1 seqs ,that could drift, but due to its superior tape I can jam anything to fit or loop, with minimum drift effects.
