1.0.13 OP-XY firmware bugs
Updated to latest firmware: 1.0.13
  • record button no longer works
  • sequencer for punch-in effects doesn’t work. Graphics shows that effect is present, but it doesn’t affect the sound.
  • Can’t reproduce yet: project backups disappeared or not saved
Does anyone have same issues?
I can’t reproduce any of those. Try loading a new project then reloading the project you were working on, does that fix it?
@pasxa check to see if your auxiliary channel is muted for the punch in FX. Hold the aux button down and see if the red lights are on/active for all your channels 1-8. Especially the track you’re trying to effect. Very easy to accidentally turn this off.
MIDI Out of the multi-jack doesn’t seem to be working properly on 1.0.9 or 1.0.13. Anyone else?
  • MTP file transfer does not work in Mac environment, op-xy crashes as soon as you view files inside;
  • after pairing the OP-Z with the OP-XY, the OP-XY no longer sends midi out with other devices (disassociating all the midi devices and re-associating only one returns to work);
  • it is practically impossible to use multisample with personal samples.
  • sometimes the graphic display of the sound wave does not match in the drum track (especially in zoom out with sampled sounds)
  • in the external midi module is not working properly (you cannot decremental the bank and program values in the pattern);
Improvements
  • Enlarge the characters…in the op-1 field everything is much more readable;
  • Ability to save samples in subfolders
  • Duplicating a Bar only duplicates the notes, step components are not duplicated.
(Odd that people are having issues with MTP on MacOS, been working without a fault here on my M1 Pro MBP running Sequoia for me. Make sure you’re using the latest version of the Field Kit app, they just released a new version a few days ago)
Is that a bug? There is no information in the manual about what gets copied. I feel two ways about it, it would be nice to have a choice.
I can’t get the LFO in the Auxiliary Punch-in FX page to do anything (Aux 2, M4). Is this a bug or am I missing something (most likely)?
