I found it annoying that the record button didn’t latch, so I made a little clip to hold it down.
You can get the files here: https://www.thingiverse.com/thing:4398464
but the Op-1s record can be latched when holding rec and play at the same time!
Yeah, but why waste a hand holding down the record button. For complex chords, holding down the record button with my pinky, then quickly moving my finger for the next chord, doesn’t really work. Maybe I just have small hands
but it will stay in recording mode without holding anything down. are you on the OP-1 or OP-Z? :))
It stays in recording mode, but the ability to start recording on a key-press is lost. ie:(you can hold the record button and press a note to automatically record things) :)))
I understand. that’s why you’ve trained your pinky! good idea
