I loaded up the same patch as you (Cermon, I think) and I’m hearing a buzzing when I crank the volume up a lot, though it’s very hard for me to tell if it’s the same type of distortion as your recordings.
I know very little about this sort of thing–is it possible we’re just hearing the speakers’ normal response to lower frequencies played at a higher gain? I’m curious if others are hearing the same thing.
dont worry that is normal. certain ranges in the very low register are just oscillating in a range that causes some rattling/buzzing. if you look at the specs of the speaker, the freq range has a lower cutoff and any lower than that the oscillations will be more noticeable in the chassis
