Hi,
Hi,
I may have to swipe this for use in Max (v7 lets you open M4L devices, iirc).
Yes, yes. Please do!
Mate this looks amazing!
As soon as I’m back home im going to give it a whirl!
Thanks!
Let me know if there is anything I should add.
The max device is Amazing!
Thanks heaps!!!
A couple of this, you may need to change the values on some of the pots?
Haven’t tested it deeply enough but you don’t get a full sweep of the parameters,
Yes it controls the op knobs or parameters but they don’t come into effect straight away, and they stop early.
Is there a way you can fix that, make it more even?
Basically the parameter won’t effect the op till the value hits about 55 or 64 and it stops at about 90 or 100,
It’s there a way you can even distribute the values so it’s a nice full sweep?
Cheers,
A
Also if you could incorporate LFOs in it that would be awesome, or maybe it could be a new device?
Max op-1 quad Lfo
Something like the lemur modulation template would be Antartica as a max device for the op.
Check this http://operator-1.com/index.php?p=/discussion/comment/7732/#Comment_7732
Adding selectable waveforms is a must
