Hi gang,
Been trying to get the OP-1 to work with Ableton running the little script with no success.
The script is installed successfully as I can select the OP-1 as a midi control from Live’s preferences (9.7.3)
I also select the correct Midi from and Midi to ports and my OP-1 is in CTRL via the Shift + Com function.
Regardless of whether or not the OP-1 is selected in the controller settings in Live’s preferences, I can trigger notes in my drum rack or any other software instrument (the same way plugging in any USB compatible device will work with no further settings required).
Following the instructions and selecting the OP-1 as a controller, I notice the red strip appears in Live’s session view showing me the script is active and running. But - away from triggering notes (as in plain USB mode/CTRL mode), none of the additional features work.
I’m sure it’s something trivial but I cannot seem to figure it out.
It’s worth pointing out the the OP-1 is connected to an iConnectMidi4+ via a USB hub but the settings are correct as I can trigger instruments.
Any help would be most appreciated.
Cheers gang!
Niko
