Even with the right settings on both units, I can’t seem to get my PO-12 to clock my Microbrute. After a lot of experimenting, I’ve determined that the PO signal needs amplification before the Microbrute will register it. Has anyone else played around with this set up with success?
my guess is the micro brutes sound is inverted which why the op-1 doesnt work with the POs at the moment… the volcas and korg stuff in general seems agnostic
I made an free iPad app which can be used to sync PO’s with MIDI. Check it out: https://itunes.apple.com/us/app/midiloop/id973104402?mt=8&uo=4
Thanks! iPhone version - sorry, most probably not.@tsoon wow your app looks good, thank you for sharing and offering it for free! sending operator love to you.Any chance you'll make an iPhone version? :)
Not that it will help in this case, but just for the record, the PO sync pulse is a 1Vpp square pulse with a little less than 3ms:
Not that it will help in this case, but just for the record, the PO sync pulse is a 1Vpp square pulse with a little less than 3ms:![]()
I think korg more tolerant…
@punji, interesting. I want one of these things, but it’s probably too rich for my blood.
Cool! You don’t have a volca you could do this for too, do you? I would be curious to see the technical differences between the signals.
^ I don’t have a Volca (yet), but according to the user manual, “The SYNC OUT jack sends a 5V pulse of 15ms at the beginning of each step”, so it seems to be a beefier (5x) version of the PO sync.
Dang. That explains it then.
It’s possible to convert the PO sync signal to MIDI using Arduino:
^ True, but if you don’t need MIDI at all, just connect to Microbute, a simple solution would use a transistor and a couple resistors to amplify that pulse from 1V to 5V.
Have you tried Microbrute’s square wave LFO out -> PO sync in?
Have you tried Microbrute's square wave LFO out -> PO sync in?This works!
