Any way to convert stereo recording on the field to mono in the box? (now with the final sound attached)
I recorded the output of the field to a dictaphone on tape and recorded it back to op1field tape via cable. But now the recording is only of the left channel. Is there a way to adjust the channels that the recording is on left and right channel?
When you’re recording back to Field, you can go to shift+com menu and turn the gold knob to set input to “mono”. That will probably do what you want.
That was exactly what i was looking for.
Thanks a lot.
Here you can listen to the output of the micro tape quality and degradation:
Second sound is the original standard sampler sound of the op1f named “free”. First one is the result after recording to real tape.
Sorry for the distortion.
But I like the Boards of Canada sound a lot.
