@erhenius ...... not sure about inbetween frequencies if thats what you're getting at? ......
That is exactly what I’m getting at.
hmm, i'm almost positive that midi notes and other values only respond to integers. so like 11.5 wouldn't work.
i think it would mostly depend on the midi device u hooked up to it.
like if the synth u plugged in had a detune knob, or a cents tuning param, u could use the midi note to generate your base note, then add some tweaking based on the CC's however u wanted to do that to get you inbetween.
theres prob alot of ways u could do it, but sinces lemur is all midi or osc, u are limited to the communication between your devices and sometimes u gotta think outside the box a lil bit to make it work. (atleast for me, i'm not a super programmer)
@masterofstuff124 yea! i was surprised (then not so surprised) that they omitted this from the volca sample. i think it would really give the RYTM a run of its money if they had included midi note pitch.
i'm gunna try to tweak the values a lil bit more cause its not 100% perfect (can't get at fractional values, which I think is what you really need to get spot on pitch). the octave above and below the original sound really spot on, but then the octave 2 above and 2 below it gets a liiiiiiiiil wonky. not sure if its something u can totally lock in, and u can't seem to get at the "shift+turn speed knob for note values" via the midi. but its better than nothing!
on the other hand, it gives your samples a lil detune effect sometimes, which i was having fun w/ last night, and if you match it against other volca samples if all sounds in tune relative to each other anyway.
i'm gunna mess w/ it against an actual keyboard tonight and see how well it holds up.
@erhenius What @dicshermsticks is pointing out is absolutely also my experience. If you want something different and want to tweak a device for something that was not intended, you’ve gotta search alternate routes. In your situation going for pitch bend and programming Lemur to send a different random value for pitch (usually control channel 1, I think), might be a good solution though. Bump if you need help.
