Hi! I’m encountering a bit of an issue when trying to sample from my laptop onto my op-1, namely loud clics and other artifacts. I’ve tried two methods so far: with 3.5mm Jack - 3.5mm Jack audio cable which then goes into 6.3 jack adapter and into my audio interface (Focusrite Scarlet 2i2 3rd gen). The other method i’ve tried is diectly from Ableton using Asio4All and new(ish) USB over audio feature but this method is even worse in terms of artifacts, even with sample rate turned all the way down and buffer size increased to the max.
What can be the issue here? Do i need a better audio cable? Should I go the opposite way and use 6.3 jack with adapter to 3.5? How do you sample?
Thank you in advance!
