I connected Op z to two external keyboards(two CME xkeys)through usb hub.
I wanted to control different tracks by two keys, but the keyboards have same midi channel so that i can only control one track. (Xkey doesnt have a option for changing midi out channel)
Except getting new keys, is there other way to change midi out channels?
Have you tried the xkey plus software? Under „assignments“ you should be able to configure the MIDI channel of your keyboard. Im not sure but it might even be possible to assign each key to a different channel (to split the keyboard).
So you can change the keyboard’s midi channel using this key combo? That’s fantastic! That’s the only thing that had stopped me buying this keyboard.
Midiflow on an iOS device can route channels from device to device, changing input to desired output, as well as mapping pressure (Aftertouch) or any CC knobs or sliders to output device CC, mod, pitchbend, etc.
