With the arp seq, is there a way to "reset" where it is in the arp seq? Example: If you put it into "each' and "type 0" mode, holding down a synth key alternates notes between octave. But if you turn the sequencer off and back on, it still remembers which octave it last played. It remembers this even if you switch the synth preset or select another sequencer.
I'd like an easier way to be able to restart a sequence cleanly each time other than just by ear. Is this possible?
Thank you in advance.
