Most DAWs let you control the direction the series of notes in a particular chord are played. Up, down, random or as fingered.
On the OP-1 I have to perfectly input my notes (let’s say C D# G for a Cm chord) in the way I want the Arpeggio sequencer to play them. This is great, but if I wanted to simply play the notes in a chord in a UP pattern what I really want to do is just play all notes simultaneously and expect the OP-1 to play them in the UP direction via a simple setting.
Here’s the problem, try to do a simple 3 chord progression (like Cm A# F) with 1/8th or 1/16th notes. Make sure that your notes are struck in a ascending pattern (Up the chord triad). What ends up happening is you get a bunch of unnecessary notes played and it sounds sloppy.
A simple firmware fix could make this so much better. Or am I missing something?
