Was wondering (for an idea/project in my head) what sizes of audio in/out jacks most people are using. By this I mean the thickness of the rubber part of the jack.
Anything to reduce weight and waste of materials! I also re-soldered my Apogee One breakout cable into one 3.5mm TRS because I couldn’t stand all that plastic. I’m getting kind of extreme these days with minimising and making everything as practical as possible (for my needs of course)
Thanks for the info and votes so far.
I mostly use a thin and light cable similar to 1st pic, but sometimes use a splitter which is still thinner than OP body, and occasionally I use a right angle cable.
I usually end up shaving down the rubber on thicker cables.
I’ve been using several kinds of cables for different setups, too many to the point where I would coin myself as a cable slut. My hope is to find cables that can adjust/rotate to diffent angles (mini USB included). Last pic is of a super cheap cable, but really hugs the op-1. I’ve got more cables if you’d like to see more pics.
Thanks @Kites for the photos.
Just want to get an idea of what most people are using. ive a little idea in my head that I want to sketch/detail further and think about making (and maybe selling going forward too)
Make sure to post it when you’re done sketching =) I’m intrigued
