Not sure if this is normal or not. This is my second OP-1 (first one didn’t even work out of the box). Did a factory reset and fully charged the unit and only have sound coming into the left side of my headphones which have been verified to have work on both sides on other audio devices.
How is the sync? Right side is sync signal in some configurations.
Already checked with other headphones? Mixer is all set to Center?
Yep, mixer is at center and tried with a couple different pairs of head phones.
How can I check to verify this?
Push metronome button. Turn green ccw
After messing around the the input jack a little more, I found I do get sounds in both sides of the headphones if the jack is only 90% in the input. Once it’s fully in, its only the left side unless I push down on the headphone connector. Any ideas or just a bad connection within the device?
sounds like a wonky jack.
Same issue here, I’d assume this means I may not be getting stereo when running into the mixer. Just noticed it happening today.
Edit* I’m a noob and forgot I had been syncing my wife’s volca sample >_<
fallen_lassen solves this for me…
Thanks a lot!
Had the same problem. Turned out to be one of the connectors between the jack and PCB had a bad connection. Just resoldered it and the problem was solved.
If you don’t want to solder i believe ifixit have replacement boards
@Defectus said:
Had the same problem. Turned out to be one of the connectors between the jack and PCB had a bad connection. Just resoldered it and the problem was solved.If you don’t want to solder i believe ifixit have replacement boards
I may try this but worried I may fry the board. Was the connector a broken solder joint on yours, or did you have you have to test with a multimeter?
if you’re just reflowing joints on the jacks, it’d be pretty hard to fry the board
even with mediocre soldering skills.
just go slow and take your time.
Had the same issue, this worked for me too. Just a little patience, a sharp tipped solder iron, all done.
worked for me thanks
