Auxiliary out audio, removed from main mix?
Basically looking to make a pre-Fader auxiliary out click track that I can send to bandmates, but could see so many other uses for this functionality.
As far as I can tell, sending to the auxiliary output is fine, but once I take it out of the main mix it affects the auxiliary output as well, is that correct as far as everyone knows?
After remembering that I bought the synth DAWG manual and looking it up, it looks like the answer is no.
@Virtual_Flannel had a solve for this, posted in Lines forum, I’m pasting here for posterity.
“There is a way to send separate mixes to each audio output. Took me a day to figure it out haha.
Set the multi out to audio output.
Have a song ready with sounds on each track for the first time to make it easier to follow the routing.
Go to aux 5 and set the input to…input.
Still in aux 5 turn white dial (mix) to zero.
Still in aux five press M2 for the routing page
Now when you route a track to the aux output it will be removed from the main output.
This was kinda tricky, and didn’t think it was possible for a minute, but is a really cool feature. If you wanted, using panning, you could do 4 mono tracks i think.”
