Back Up Question
When you back up by saving patterns and projects to your computer - do the synths save as well? What if I change the selection of synth engines I have on the OPz ?
u gotta save the samplepacks folder too
thats where all your synths // sounds // samples are stored
not 100% sure if all your specific settings are stored in there or not tho
The easiest way to save everything is to save everything…i drag and drop everything on the OP-Z disk to a year-month-day folder on my computer.
While @docshermsticks is right about the samplepacks, the parameters (ADSR, LFO, arp, pan, etc) are saved in \config\userpresets.dat
And yes, if you move synths around )or remove them) with the “Configurator” part of the OP-Z App, this definitely breaks links to your saved presets…learned this one the hard way!
Hope that helps,
