Hey anyone know why after charging the op1 , the batterie marker doesn’t reach to the red light?
I mean, plugged to the wall reach the red ligth but when i unplug it just mark 3 yellow points
it’s because TE can’t program a god-damned battery meter.
Thanks for your qick response! It happened after jsing ot plugged for a couple hours. First time i used it plugged. Not sure if that has anything to do with the issue. It’s funny how i take care of this little machine like my third child.
even stuck at 3 bars I’ve gotten a solid day out of it (6+ hours screwing with it), let it sit for a few hours before bed playing FM radio and Tombola, and then went to bed just to finally kill the battery.
Got the same problem with mine, so annoying. Factory reset fixed it until the next charge, was so glad at first
Maybe run out batterie and a full recharge solves this issue
TE suggest -Run the battery until it switches off on its own,leave the power switch in the ON position. Plug into USB device and charge for 4-6 hours.This should reset battery meter.
I've found the tip to charge only from a laptop(mine's a macbook) useful.I first used a wall charger (1amp/5v phone charger) and it didnt like that ,so I done above and now I always charge with the comp ,so far its working.
I will try chargin. Form my pc laptop. I guess , in my case worked better for the wall with the phone charger though’
It is a bit of an enigma that meter.I have to go with KrisM now,since last night its changed and turned itself off with no warning flash on one bar (today).The battery does generally last a while.
my op1 sometimes don’t charge itself properly, I mean:
These things in an expensive device are really scary ! I love my op1 and i hope it keeps in good comdition for many many years
Just try to uncharge it completely…And then let it charge until it’s full, it will recalibrate the leds
