i’m curious what cables y’all have found to be the best when taking full advantage of all the slots on your TX-6, especially when using in a setup with POs and an OP-1(F).
thanks for any and all input!
I use these, thin enough to fill all 6 sockets with clearance.
I use these, probably the same tip casing size as the MaGeeks also listed though. I like the right angle option though for op1 and others.
thanks so much all. both of looks are nice and slim and should work well. im intrigued by these 90deg angle ones, now i think of it, its nice not having too much “stick out” perpendicular to the device while plugged in.
