hey guys, i’ve been searching for the best voice recorder for the past few days because i need one for lectures, meetings, and personal notes. i read reviews from the new york times, pcmag, and popular mechanics, and they seem to recommend these two options:
Plaud Note Pro AI Voice Recorder Transcribe & Summarize for Meetings Calls
however, i’m having trouble deciding which one would be better for my needs and could use some expert advice. i mainly want a recorder with clear audio, good battery life, simple controls, and enough storage for longer recordings. i might also use it for interviews and lectures, so having a good microphone is really important.
which one would you recommend, or is there another voice recorder i should look at? any suggestions would be appreciated. thnaks in advance
I don’t know anything about the items you’ve linked to, but I can recommend the TP-7 by TE.
Yes, it is expensive, but I really like it. I got mine this year in their sale and I really like it. It has a built in mic which is totally fine to record speech, has a 1 button memo function and long record times. There is some initial menu diving to set it up as you’d like, but once you’ve made those settings then you can forget them. I believe there is a transcription app to covert recordings to text.
On this forum, this thread wouldn’t be complete without mentioning the Rabbit r1. The Hardware was designed by TE. I have one and I’ve used it to record lectures on occasion. It works fine, though (as the page says itself) you will want to have some external power.
An old Olympus LS-10 or LS-11 is a must have for a small budget. Olympus LS-P5 is the modern update, more expensive. Both of them are probably the best voice recorder I’ve ever used, perfect sound quality, solid and easy to use.
