Hello
I am new to OP-Z and wanted to get your opinion on the Bluetooth connectivity with the android app.
in my case (android 8.1.0 on Blackberry Keyone), establishing the connection is a little bit difficult, but maybe I am not doing the correct actions.
Here is what happens:
- lets start with my OP-Z already paired/connected and visible from the App, all is fine.
- Switch the OP-Z off, OP-Z disappear from the App, good.
- Switch OP-Z on, short press on the connect button, led go green, then off. nothing appends in the App. try several time, same result.
- Longer press on the connect button, or various press, nothing in the App
- What seems to work is a longer press on the connect button, at some point the led goes red (maybe erasing the pairing?), then off. Then I press until the led goes blue for a very short time and I release the connect button, and at this point sometime the App see the OP-Z
Not easy…
I know the android App is not final.
Can you tell me what appends to you?
I was expecting that an OP-Z known/paired with the android app (and/or phone) would be reconnecting automatically, or with just a short press of the connect button.
Many thanks
Gilles
