Brain bug back again?
It seems the brain bug is back on the OP-XY (on 1.0.25). On long multipliers (eg 8) on the brain track, the transposition triggers late again, so the first note on the audio track at the start of a bar won’t transpose. I’ve transpositions on the brain at 1, 5, 9 and 13 (each extended over 4 notes on an 8 multiplier) and they trigger late.
Weirdly, if I microtime forward the triggers by 1 (so they trigger early) the transpose on 9 and 13 trigger correctly even with quantise on 100, but the transpose on 5 doesn’t. Even with quantise on 0, the transpose on 5 only triggers correctly if I microtime by 5 or more.
I can microtime the first note on the audio track and it works (with quantise on 0, not 100 - which is expected)
This is such an annoyingly weird bug.
i think in general, track scale is way buggier on XY than on Z. i’ve reported a couple bugs related to it. The one that kills me the most is that on a track scale of 4 or 8, if you play something syncopated where there are 16th notes on the last step, the quantizer completely screws up the rhythm. Only on the last step when it loops around to the beginning! Ugh…
It seems to be a mess of quantising, track scale, and how and when the notes on different tracks are ‘prioritized’ when triggering at the same time.
Interestingly, I’ve just discovered that the brain can have the arpeggiator, maestro or hold applied to it! Having an arpeggiated brain applied to an arpeggiated audio track leads to all kinds of craziness. And applies also to punch-in effects and the tape!!
I had very similar issues with the punch in track as well. There seems to be a number of annoying timing issues like this on the device (which is one of the reasons I returned it).
Omg. I had this one too. So annoying. At first I thought it was my playing but I’m not that bad. Lol
yea… hehe that was my first thought when i first encountered it too, but i simplified the rhythm and made it like a 1 bar thing and used track scale at 4 so that it became 4 bars, repeating 4 times. it sounded fine on the first 3 but the 4th bar is always screwed up because of the bug.
