I received my OP-1 two days ago. Plugged it into the wall to charge over night, unplugged it and went to turn it on and it wouldn’t. It’ll turn on if it’s plugged in but the battery indicator lights don’t show any progression or blink.
I am super brand new to this and honestly I feel a little discouraged that I can’t even get it to charge right. I’ve tried to look through other various posts for a solution and haven’t had much luck.
Have you tried this? If your unit still has enough battery to turn on, turn it on, hook it up to computer, press SHIFT + ALBUM, then choose T4 which is OPT (option) mode. Use blue knob to choose usb charging on or off. I would try charging it with both options (usb charging on-hooked up to computer/usb charging off-from an electrical outlet. When you say it’s not charging, what method were you using? Wall socket or computer?
You’re misinterpreting the manual @joeyfivecents. The reason for setting USB Charging to OFF is to avoid any potential interference with audio. I believe it defaults back to ON when the OP-1 is power cycled. And regarding this setting, charging by computer or wall outlet is irrelevamt - it just needs to be set to ON to charge at all. Hope this helps.
So just leave it on and on the charger for a while? Should the battery indicator lights be moving up and down? Right now it’s on, and plugged into the computer, but there’s no battery lights.
I was just trying to see if there was a combination of things that might not be set right, irrelevant or not. Sometimes when these things get buggy, a new suggestion works with no explanation. That’s been my experience. Just trying to help.
