This is my process for copying the .aif files back onto the OP-1 and the issue I encounter:
I suspect the computer wasn’t finished copying the files when you ended disk mode on your OP-1. Be sure to force the computer to flush the USB transfer cache by “safely removing” or unmounting the USB drive BEFORE leaving disk mode.
@<a href=“https://www.operator-1.com/index.php?p=/profile/4205/Diffrentstrolks” class=“Username” style=“margin: 0px; padding: 0px; border: 0px; outline: 0px; font-weight: bold; font-size: 15px; font-family: “lucida grande”, “Lucida Sans Unicode”, tahoma, sans-serif; vertical-align: baseline; text-decoration-line: none; color: rgb(66, 157, 168); background-color: rgb(252, 252, 255);”>Diffrentstrolks<span style=“color: rgb(37, 38, 30); font-family: “lucida grande”, “Lucida Sans Unicode”, tahoma, sans-serif; font-size: 13px; background-color: rgb(252, 252, 255);”> Yeah, definitely a weird one. Things off the top of my head, not trying to sound condescending:
Thank you both for the suggestions.
I just followed my steps exactly as outlined above for track_1.aif through track_4.aif in the Tape folder.
@Diffrentstrolks yes I think you may have nailed it on the head: it may not actually be possible to transfer it back. I’m guessing the actual easiest way to do this would be to actually record the album tracks from your CPU, into the sample input of the OP1, and record it directly to Album again without master FX or the compressor engaged
While that will work, a more elegant solution might be to get to the bottom of the real issue: the “album” tracks are actually AIFC format sounds…ever notice that no matter how long or short a tune you have recorded to album that the file size is always 60.5MB (62,016KB)???
Anyone know how to parse AIFC files? (Audacity will open them, but not save them apparently)
Best,
SOLUTION FOUND!
I had the same problem, was looking everywhere to find a solution, and could not find anything.
This is the solution:
The OP-1 checks if it is a different file by checking the date the file has been created, and comparing it to what it knows about the file. If the file has a different date than the previous one, then it doesnt like it.
You can trick the OP-1 by modifying the creation and modification time to the original.
This is a nice tool which I used to do this: Get Attribute Changer – Attribute Changer
Its pretty easy to do, just right clicking on the old album files, changing the dates to the files you have in your op-1, and then uploading the altered files to the OP-1.
Hopefully I helped some people around, as this info would have been very helpful to me if I have found it.
