I havent found it in the guide. When I have multiple chained patterns with different filter settings for example. During playback i want to change the paramtere of the filter while holding the record button and twisting the yellow dial.
At every start of a new pattern the filter settings jump to the previously “old” setting and records new from there on.
Is there a way to have a continues adjustment of the parameters while playback?
I would like to know the same…I guess they’ll have to change this in a future update.
Even the POs can do this
I have exactly the same question.
I’m playing with a filter during all the song. Live, i can’t do anything else because it seems that i canno’t record parameters’ changes in a chain but only in a pattern.
Someone have a solution for this problem ?
Best I can think of is that you can copy and paste parameters from one track to another pattern or you can copy the parameters from one pattern to another pattern.
THIS is a feature they should add on next firmware versions…
I was surprised, that it is not a standard setting on the opz. The Pocket Operators had done this from the start.
