When I hit play on the op1 it takes a couple of bars for the Pamela’s clock to start working properly and I’m noticing that the kick is not on the mark … anyone experienced this and is there a solution… it’s really shit if this can’t be fixed
So I have just got a midi to cv module so will attempt to connect that way … I tried this before using the midi in on a subharmonicon and got lots of weird static background noises… but fingers crossed going into the ALM midi to cv it will work… this has been quite a experience ffs
I have no idea what you’re saying. “Pamela’s clock”???
My OP-1 not OP-1f has issues with the metronome starting off, if that’s what you’re referring to?
pamela’s new workout is a eurorack module
Pamela’s new workout is a eurorack master clock that’s capable of lots of simultaneous clock diversion… it’s very useful but at the moment when I use the Op1 field to run the Pamela’s New Workout it skips a couple of pulses meaning it’s just slightly out of sync … as both are very popular devices as was wondering if anyone else experienced this issue and if clicking via midi was the answer…
Are you using the PO Sync clock setting set to 1/16th? That should work.
PNW is a little bit fussy with clock input though. If the PO Sync doesn’t work then I would say definitely go for a Midi module. ALM’s “mmMidi” works really well with PNW.
ah! i wonder if it has anything to do with the low voltage on the op1 sync pulse?
most things are looking for atleast around 5V (or even 3.3V)
and the op1 (and PO) sync pulse is closer to 1V
not sure if hte field suffers from this as well?
i def have had issues w/ syncing POs and OP1 to other things because of this
amplifying the sync pulse fixed it right up
Yes I was using the right PO clock … I hope the mmmidi is good … last time I was using midi out on the field I was getting weird static … but hopefully the mmmidi clears it up … thanks for getting back
Interesting you say that. I was sending Midi fro the OP-1f to Hapax and Hapax was all over the place. I sent it to my DAW instead and it was solid. I assumed it was Hapax at fault… but maybe there is more to it…
How are you going to connect OP-1f to mmMidi?
Op1 to Kendal usb to midi converter then into to mmmidi to cv
It’s totally working now so if you want to sync a PNM with a OP1 Field go Midi using the MMMidi is my new recommendation… we got there
Hi @MrBongo, Something like this? I’m starting on modular and I have an OP1 field too… thanks!!
the field is already a USB MIDI Host
so u shouldn’t need another one in the mix
just go straight from op1 to midi cv converter
Thanks! I understand but, how do you send clock and run signal to Pam’s pro?
if u look at your diagram
just replace the kenton usb midi host
with any class compliant usb to midi adapter
op1 to usb midi to midi cv converter to pams
Thanks! Would you recommend any? Sorry I’m kind of new in this ![]()
I just found this cable! USB C to MIDI. Thanks @docshermsticks
u want one that doesn’t require any drivers to work
they usually call this class compliant
look for verbage in the item description for something of that nature
and u should be good to go
