Hi! I’m trying to connect my OP-Z to a Behringer Crave via USB.
I just want to send midi notes to the Behringer Crave. But I can’t make it work.
I tried different tracks and different MIDI-channels. What am I doing wrong?
I have a USB C to usb type A + USB A to B. Do I have to get an OP lab?
easy, connect Crave to iphone via usb (usb to lightning connector). than connect op-z to iphone via bluetooth. now your iphone is a midi host, on the iphone you can further configure in what way you want to use your midi channels.
and yes, just get op-lab, Crave looks like it made for CV inputs so its more fun.
I dont have Crave, so I dont know for sure. usb c cables have to many functions these days so it can get frustrating. some cables give power to the devise and some cables take power out the device. so if you plug Crave directly into op-z, its a gamble to know for sure what it will do.
just use a method i gave you, it works for sure and at the same time you can use your op-z wirelessly
Thats true, but maybe Crave asks for additional power from usb , and op-z is not powerful enough to power Crave. so you would need a usb hub with additional power supply, pretty much like iPhone usb dongle
it will convert usb B synth into Bluetooth midi.
but you still need iOS or android as a midi hub to connect op-z and Crave.
this is if you care about wireless set up.
there are many good approaches to this situation, i guess it depends on user set up preferences.
I use this to connect my Opz to my Circuit OG. An usb c to usb b cable did not work, this one works fine and has usb c already. Got ist cheap on Amazon, it was about 20€
Crave to Iphone with usb and then bluetooth should also work fine, i used the midimttr app, to select Circuit as source and Opz as destination. Midimttr is a free app.
