Correct. Tried with a sufficient charger and it worked.
Recommend the 20 watt USB -C charger as it charged my iphone SE 3rd gen and my OP-1 at the same time.
As I posted the original question, I wanted to update the post with my outcome.
I started with an official lightening to usb apple adapter but as pointed out in this thread, although it works on an iPads, iPhones need additional power. Apple do a second adapter that has lightening at one end with usb and an additional lightening at the other to supply additional power.
I searched for the cheapest unbranded Powered adapter I could find and with the use of an additional lightening cable I too was able to access my Op-1 on my iPhone.
Thanks again to everyone that contributed!
I’m just going to add here that as of Jan 2024, this appears to be the same situation for the OP-1 field and iPhones.
This results in some synchronization (with a percentage of completion), after which the official Apple Files app will display SOME contents on the OP1F, but only the “synth” and “drum” folders – not the “mixdown” or “tapes” folder.
Note that:
