I need to use my iPhone to connect to my op-1 to manage samples. The only post I can find online about it are 5-6 years old that suggest using various USB memory sticks with WiFi that are no longer available.
Has anyone out there got this working in some way? Any help would be really appreciated!
they changed this a couple years ago (in i think iOS12?)
u can access the files via disk mode ipad iphone now
i believe u just use the built in files app?
I’ve brought an office apple lightening to USB adapter. I switch to disk mode on the OP-1 and then plug in the cable. The cable that joins the op-1 to the laptop on the op-1 lcd flashes green BUT the device does not show on the iPhone.
I have tried a different iPhone, restarting the iPhone while connected and sorts of combinations. What the hell am I missing here?
I can confirm.
On my iPad Pro the connection works with no problem. Files app shows the OP-1 as a disk.(NO NAME)
On my iPhone Files app does not show OP-1 at all.
Same thing in both devices with the OP1 Manager app.
yea thats def it
just tested it w/ my iphone
if u use the CCK that has the extra charge port
and plug that into a power source
it shows up in the FILES app like it should
didn’t matter if i had USB CHARGING turned OFF or ON
not sure if order of operations matters
but i plugged everything in before turning on the OP1
OP1 to phone w/ CCK
CCK charge port to USB power plug
then i turned the OP1 on
then i went into disk mode
took a beat to sync up
but then on the OP1 screen the lil computer was blinking a lil square
and the cable started flashing green and i was g2g
without the charging port plugged in
the lil square would show up
but the cable never flashed green
