Hi everyone, it’s my very first post here, I’m so excited to have found a community of people sharing the same love for that little piece of metal !!
the OP-1’s MIDI spec is not complete enough to enable control of its parameters via a MIDI controller, with the exception of using the MIDI LFO for CCs 1-4.
^this depresses me to no ends. I have written to TE about this numerous times.
But it’s stil possible to use it with bigger keys ? isn’t it ?
yes, @ciow, you can trigger MIDI notes with a keyboard once you get them talking to each other. Using my Oplab I’ve played my OP-1 with my EWI 4000S.
Ciow do you have an Iphone or ipad? If so, you can do this:
@Kites this is absolutely awesome, i wouldn’t have thought about that at all…, thanks !! @KrisM , I guess it’s an original experience to use it with the EWI 4000S ! Still, the OPlab is a bit too expensive to me, so last question and then I’ll stop with my begginer questions : Is The Kenton USB host is enough for what i want to do with my op-1 ?
I would just look for the original iConnectmidi1, it’s cheaper, but it may be difficult to find since it’s discontinued. Some members will put there’s up for sale every once in a while.
To clarify with anyone else; the iconnectmidi2 needs a computer or tablet in order to work right? It doesn’t work as a standalone interface? Also, we couldn’t just use a micro USB adapter to a USB A to Midi converter cable could we? The OP-1 can’t power it right? The Midi gods wouldn’t allow it right?
^it is a standalone unit. should work fine without an ipad/comp. Those are just used for editing the ins/outs of ports.
should work for only the keys outta the box. http://www.amazon.com/iConnectMIDI2-Connective-Interface-passThru-Technology/dp/B00EV4A0PG/ref=sr_1_1?ie=UTF8&qid=1406393687&sr=8-1&keywords=iconnectmidi
It looks good ! So to clarify things in my mind, I need to connect my Op-1 to the USB port in front of the iMidi, and then use a midi-usb cable to connect to my keyboard controller ? I’m sorry but I don’t have a lot of money to spend and I want to it to be efficiently used, cables included
I’ve seen the iConnectMIDI2+ for cheaper than the Amazon prices. eBay would be a good source to score one around $50. But to answer your question, the OP-1 would connect in the front of the icm interface and then your midi keyboard would connect on the back to the 5 pin midi ports.Do you have 5 pin midi ports on your keyboard?
You also might need a mini USB cable to B USB cable, or maybe this adapter would work for the OP-1 http://www.amazon.com/USB-Female-Mini-Male-Adapter/dp/B0016RNX2I/ref=sr_1_4?ie=UTF8&qid=1406418247&sr=8-4&keywords=mini+usb+to+usb
I’m thinking about getting a beatstep, you could do this with it. http://youtu.be/Qv7PY1AQLcI
