I found out recently that through CV sync, the sequencer “Nanoloop,” and the tracker “LSDj” can be used with the Pocket Operators using a modified cable.
Have you actually done this, or is this just a theory?
It works, and you can also sync with midi and the volca series. I don’t have any of the POs to try it with, but Cheapshot uses a PO-12 and nanoloop in his live sets:
i got LSDJ and the PO-16 and i conected them via a cable i got from https://evadeanddualitymicro.bandcamp.com/merch/korg-monotribe-volca-sync-gameboy-dmg01-cable-for-nanoloop-lsdj-slave-mode
i got LSDJ and the PO-16 and i conected them via a cable i got from https://evadeanddualitymicro.bandcamp.com/merch/korg-monotribe-volca-sync-gameboy-dmg01-cable-for-nanoloop-lsdj-slave-modei cant get it to work, if some one could show me, it would be much appreciated!
i had mine working w/ nanoloop and PO. not sure what is going on w/ yours, not too familiar w/ LSDJ. is there any other sync modes you could try on LSDJ? seems like the pulses being sent out are not the correct timing for 1:1 sync.
but what’s that got to do with the original post?
See comments below this video:https://www.youtube.com/watch?v=eNSawFuMWxs
not sure, how did you get it working with nano loop?
i plugged them in and set the sync mode on nanoloop to the proper timing configuration.
the comment from the youtube video is pertinent.
you may need a clock divider.
also, check the sync modes on both of your POs.
also says on the bandcamp link for the cable, that the gameboy must be the slave…not sure how u have it hooked up.
Well im lost!
The Nanoloop sync cable looks simple enough the build by butchering a DMG cable and wiring it up to a 3.5mm jack.
Also, make sure your versions are right:
ive only got nanoloop 1.6 unfortuantly.
