Is there a way to copy the settings you make in drum mode from one key to another. I could have sworn I did this before, but I can’t remember how and I can’t find it in the manual
yes! i think its like hold key, press lift to copy, then press (hold?) another key, press drop
unless what u mean by settings, is just the settings and not the sound.
That’s right, just like the doc said… hold key, lift, hold another key, drop.
Just to add though, doing this will trigger a bug whereby dropping any audio into a drum sampler thereafter (using lift from tape and drop into drum) will no longer work. You have to switch off and switch on the machine to reset the bug, as it were. I’ve report this to TE at every opportunity I can as it’s a little annoying. Actually, I owe them a video demonstrating the bug.
Thanks everyone, that helped a lot.
