Copying samples from one drum sampler to another
Hello,
First post here. I’ve been working with recording a bunch of random samples and making drum kits out of them. I record all the samples on tape then use ear to record into drum sampler. Now I know the drum sampler only allows 12 seconds so I split the samples into different slots since all the samples I recorded are longer than the allowed limit. I was wondering if there was anyway to lift and copy samples from one sound (i.e. 1) to different sounds (i.e 2 or 3). I know I can probably do this using the computer but would like to know if there’s a workaround just using the Op-1.
Thanks in advance!
Dis would be nice, but I don’t think you can copy paste slices ie. Export them to other banks. Only within one bank ie. 1-8. I could be wrong. On treadmill
You don’t need the ear to record into the sampler, just lift the 12seconds from tape into the Sample slot. That means you can cut the extra/new drums within the tape and then lift them back into the slot.
https://www.operator-1.com/index.php?p=/discussion/2777/howto-add-a-sound-to-an-existing-drumkit/p1
Awesome! Thank you all!
