Countdown option for recording on the tape recorder?
Hello everyone,
Where do we activate the countdown option for recording on the tape recorder? I would be very grateful if you could help me. Unfortunately, I couldn’t find it.
Shift + Record, and then hit Play : countdown starts… (of course you need 1.6.0 or later to do so)
Hello, thank you for your reply. I installed the latest update. I believe this is a feature that came with the update. I’ve been trying what you suggested for a long time after installing it, but it’s not working! I was wondering if there might be another setting. What could be the reason it’s not working? It’s a strange situation. Thank you.
Step-by-step: go to tape, hold shift +record, press play. If countdown doesn’t start for you, maybe try to update to 1.6.5 and try again. It works for me.
Thank you for your reply. I have already installed the 1.6.5 firmware. Unfortunately, it is not working. I am following your instructions step by step. It is not working. I also recorded a video to show the situation, but I cannot upload it. It is a peculiar situation.
may be you are in Free (sync) mode..? countdown works in Beat Match, MIDI sync and PO sync modes for me
Hello,
Yes, that’s it. Finally That was the problem. Free sync mode was on and it wasn’t working. When I turned on Beat Match mode, the problem was solved and the countdown is working. Thank you very much
@axiefe it was actually @electrafa who solved your problem but now I know too this solution :wink:
