Hi all, please forgive me if I’m jumping the gun here a bit, but I’ve had the OP-1 for a couple of hours and there are a couple of issues I’d like to bounce off the forum:
1) One of the first things I did was to update the firmware and I can’t seem to see any presets at all - I’ve watched a bunch of run-through videos on youtube and it seems that there should be loads of presets available as starting points and I have none in my list, other than half a dozen in the sampler module. Everything else has nothing under it. Same for the effects section.
2) Is it normal that the knobs are a little off-centre? It’s probably just my OCD but my knobs are all off and it troubles the aesthete perfectionist in me. The knobs do seem a bit scratchy too, and, I’m guessing this is normal, the resolution on a knob turn is very low/steppy.
3) Is it normal that the tape should be right at the end of the reel on first use? I spent 15 mins or so wondering why I couldn’t record anything to the tape and then realised it was because it was at the end of the reel and needed rewinding. Does this indicate that the unit may have been used before? Seems a weird starting point for the factory settings.
3) The speaker really does sound like crap, right? I’ve read enough reports of the OP-1 speaker to know that this is normal, and of course I wouldn’t expect much from a speaker of it’s size, but gosh it’s pretty much unusable. The speaker on my iphone is better and that’s tiny by comparison.
Thanks for any illuminations on any of these, sure this won’t be the last time I defer to the forum!
