Trying to make sure I understand the oplab module correctly. It has a gate output and CV output for pitch; however, both of those ports are stereo (trs) connectors. If I were to get a couple single TRS to dual TS cable, I would then have access to two admiral CVs for modulation, correct?
Those work perfectly for me.
The tip/ring-labelling also helps finding the right connections without any trial and error.
Tips are CV (1) or gate, rings are CV2 or CV3.
Also: Keep in mind that the oplab module is only capable of the range between -5/+5V while many modules accept a range between -10/+10V. So you might not be able to modulate on the „whole range“ with only the oplab module.
Would that actually work though? Because it’s still TRS on both sides, so if I connected w mono CV cable on the end, wouldn’t it just duplicate the Tip signal and ignore the Ring?
How do I use CV2 & CV3? Isn’t it possible to do sweeps? And if so, how? Is the only way to use them to parameter lock values? That still doesn’t seem to work?
