I like to lie down (usually in bed or on sofa) and mess about with iPad music making and had looked forward to replacing this with the OP-Z but because I’m holding it on its side it thinks I am using the mic and certain functions are disabled. Very frustrating! I take it there’s no way to disable the mic feature?
Would be good to know. Isn’t there a text file you can edit?
Yes, in content mode you can access the general.json file. There you can set “disable_microphone_mode” to “true”. I guess this should help!
Wow, it worked a treat, thanks! I didn’t expect a positive outcome, was just having a moan.
Thanks!
