DIY DMX USB adapter for the Z
Hi @HOLY !
Better late than never :smiley: I actually had the exact same problem as you, I couldn’t get the DMX USB connection to work with the Arduino clone I had lying around.
The important feature that the microcontroller needs to have is a FTDI chip (a type of USB/Serial connection) that is required for the OP-Z’s DMX connection. The original Arduino Nano (not the “Every”) has this chip. I actually found another Arduino Nano clone on ebay that has the FTDI chip:
With this clone it worked perfectly!
Time to show off my setup: I integrated a LED strip into my case with the OP-Z, a Keystep and a Digitone. The LED strip is controlled by an Arduino Clone. Everything is connected with a USB Hub.
Works quite well! (sorry for the sound, using the OP-Z’s internal speaker)
Woah, this is awesome!!
Once again, I am trying to get a DIY-DMX setup working and am absolutely frustrated…
CAN ANYBODY HELP ME, PLEASE?
What I’d like to achieve:
Use a light fixture like this https://www.aliexpress.com/item/1005005099938475.html?spm=a2g0o.order_detail.order_detail_item.2.7c20f19cKNkfQn
What I have tried so far:
Hook the light fixture from above to a SP201E DMX 512 Decoder https://www.aliexpress.com/item/32995305621.html?spm=a2g0o.order_list.order_list_main.15.4efe1802Q91HJs
, powered by some 12V
https://www.aliexpress.com/item/32983648084.html?spm=a2g0o.order_list.order_list_main.27.21ef1802IPGuVQ
Trying to use this as a USB to DMX converter
https://www.aliexpress.com/item/1005001620687525.html?spm=a2g0o.order_list.order_list_main.39.21ef1802IPGuVQ
I can get some lights to light up, when connecting them to the Decoder, but nothing seems to actually be controlled by the USB DMX.
I am a complete noob, when it comes to electronics…and my experiments of just plugging random cables somewhere probably aren’t safe. I’d really like some help and someone to walk me through it. Would be willing to pay for it!
I am also interested in this, but also a noob :wink: It also got frustrated trying to find practical information on this online. I got the vanilla version working at least (op-z > nucleum usb hub > enttex usb pro > Stairville 240/8 LED RGB bar - works like a charm, but I would like to build DIY fixtures eventually). How did you connect everything? Maybe some photos or diagrams would be helpful.
Hey everyone! I’m sorry I fell off the face of the earth but I’m back and I’ve made a new update. I’ve implemented a wireless Dmx (artnet) system using the Op-z and a sparkling ESP32 Thing microcontroller. I’ll be posting a tutorial in the coming days but ultimately I’d like to make lighting using the Op-z as simple as possible and hopefully make it easier for others to take things even further. I’ve mostly been shooting in the dark on the lighting side of things but with this new implementation, I’m hoping it makes it cheaper and easier to put some visuals to sounds.
In this video:
OP-Z is connected to a esp32 thing which acts as a artnet host.
Each string of LEDs acts as a wireless battery powered artnet node. Each strip is set up to act like 4 segments of LEDs, matching the 16 LEDs on the Op-z. The strings/strips of LEDS are connected to a microcontroller running WLED Which receives and interprets the DMX data over wifi
DIY artnet OPZ lighting
DIY artnet Dmx OPZ lighting test
Can’t wait for these instructions! Great job :slight_smile:
Wow, exactly what I was looking for! Tutorial PLEEEEEAAAASE!!!
Hello all,
Just wanted to pop in and say thank you for the responses in this thread. Through this thread I managed to make something using a standard XLR connector and a MAX485 chip.
Everything works fine except I get some missed frames on the fastest strobe effect on the OP-Z. The second fastest strobe works as expected.
I would much appreciate if anyone have any thoughts on how to solve it so that even the fastest strobe doesn’t miss frames.
This is what I came up with, my CHEAPTEC DMX USB Pro.
This is the code I’m using:
#include "DMXUSB.h"
#include <DmxSimple.h>
#define DMXUSB_BAUDRATE 115200
#define DMX_PIN 3
#define DMX_MAX_CHANNELS 128
const int enablePin = A5;
void sendDMX(int universe, char buffer[512]) {
  if (universe != 0) return;
  for (int channel = 1; channel <= DMX_MAX_CHANNELS; channel++) {
    DmxSimple.write(channel, buffer[channel - 1]);
DMXUSB DMXPC(Serial, DMXUSB_BAUDRATE, 0, sendDMX);
void setup() {
  pinMode(enablePin, OUTPUT);
  digitalWrite(enablePin, HIGH);
  Serial.begin(DMXUSB_BAUDRATE);
  DmxSimple.usePin(DMX_PIN);
  DmxSimple.maxChannel(DMX_MAX_CHANNELS);
void loop() {
  DMXPC.listen();
