Does OP-XY with Decksaver Still Fit Into Field Bag?
Hi,
I currently keep my OP-XY in the dedicated Teenage Engineering Field Bag. It’s a quite tight fit and I feel like the potentiometers (encoders) are not sufficiently protected.
I plan on getting an additional Decksaver. Does anybody know if OP-XY with the Decksaver still fit inside the Field Bag?
I have the OP-XY and decksaver. It sounds weird but it is really tight in the large black field bag but goes easier into the white version of the field bag (I use this for the field.
So definitely not identical internally for me but might be a one off maybe.
I’d get the black version and be prepared to send it back if too tight (you also have to release all of the Velcro straps etc before pushing it in. Once in there’s a decent amount of protection and have had it on flight hand luggage ok with no problems.
Theres no black version of the separate shoulder strap, only the white version at the moment.
Hope the above helps.
I can get the XY with decksaver into the black bag. It is a tight fit but with the decksaver in this doesn’t really matter
Fits into my black bag, just need to connect the parallel Velcro straps to the front of the bag!
